I find analog voice through a repeater much better than any digital. Digital voice sounds nasally, volume varies dramatically.
This is often due to poor setup of the radios.
Many years ago I was in the market for a new trunked system to replace an aging/failing SmartNet system.
Tried MotoTrbo, and it sounded like crap. This was from a Motorola sanctioned shop, one of the bigger ones in the state.
Tried an NXDN repeater running side by side. Night and day difference.
The problem with digital is that there are a lot of variables involved. Manufacturers can compensate for most of it, but it requires some knowledge when setting up the radios.
When I was turning up our NXDN trunked system, it took a lot of trial and error to get it to sound good. Even then, I turned to Kenwood for assistance in setting up the radios.
When listening to DMR there seems to be a lot of signal variation with some squawks and squeaks that are 10 db above voice and extremely annoying. This is particularly annoying for people with hearing aids. I am still trying to find where digital has less interference and trash, as when using an analog repeater that has not been an issue to me. At least with analog and dropping of signal, one can generally make out words to know what is trying to be said. But digital is useless on fringe. I cannot comment on simplex as have not used digital in that environment. But I can see Digital having less white noise in this environment.
I agree. I still prefer analog.
However, I have had the opportunity to do a side by side test, with most variables controlled:
I've got two VHF analog systems, repeated, 12.5KHz FM. Quantar and MTR2000 repeaters, wireline control from dispatch, Zetron 4048 consoles. Link between console and repeaters is mostly fiber optic, with the last stretch being twisted pair, known good cable.
Kenwood NexEdge trunked system. 12.5KHz digital channels, NXR900 repeater with Crescend amps. Radio link from dispatch.
Same dispatcher, same console, same mic.
On my end:
Kenwood NX-700 VHF mobile, 12.5KHz FM analog.
Kenwood NX-900 800MHz mobile, 12.5KHz NexEdge.
Same speakers, same vehicle.
Dispatcher sounds good on the VHF analog systems.
Seconds later, hear her talking to me on the 800MHz digital system, and it sounds better. More dynamic range, cleaner audio.
Side by side, same radios, speakers,dispatcher, etc. and the NXDN sounds better, at least in my opinion.
I've also got a clear shot running about 80 miles south down the highway, clear line of sight from our repeaters all the way.
VHF analog slowly deteriorates towards the fringe, but the 800MHz digital stays the same.
Until you hit the wall, then they both drop.
Beyond the 80 miles, I'll occasionally get a spot of coverage from VHF, but 800MHz is gone.
But, I do agree, I'd still take the analog if I had the choice.
And, as I said, so much of it involves having the radios set up properly. Unfortunately I think most radio shops don't put much effort into it.
