I have had the same error on all 3 PSR800s that I've had upgraded to a WS1080. I used the EZScan software to attempt to upgrade the CPU and DSP on the scanners. Usually the EZScan will show an error that the update failed after it has wiped the scanner's CPU software. In the past I would just reboot the PC and try with the direct update software from Whistler without issue. Then I would upgrade the DSP and all worked fine after.
This this last scanner I keep getting "Scanner response timeout!" using the CPUUpdater_WS1080_U4.8.exe. The updater will see the scanner on the correct port and will go through the "Upgrading CPU" but the error shows after that. I've tried on three different PCs (1 Win10 and 2 Win7). I've also tried about 5 different USB cables. Anyone have any suggestions?
