APX 700XE 380-470 flash kit
N1XDS
ÆS Ø
Does anyone know how much the cost is for the 380-470mhz option kit for a APX 7000XE radio? My radio has the UHF2/700/800 in it...I don't plan on using the UHF-2 side. I would be keeping the 700/800 and just adding the 380-470 UHF-1 part. The versions of the radio are:
Firmware 16.22
and software 16.0
If that helps.
GTR8000
NY/NJ Database Guy
BEE00
Can't be done, the radio is not hardware capable of the UHF R1 split.
Project25_MASTR
Millennial Graying OBT Guy
Texas
The cost of obtaining a R1/800 MHz APX7000XE with the flash options you require.
AESFTW
I'm curious if you can simply switch out the RF deck, reflash, and then align the radio or if there would be other hardware changes required.
Project25_MASTR
Texas
Negative. There is no way Depot will change the components on the 450-520 board to the components required for proper operation at 380-470 MHz.
No. You'll need depot once the boards are changed out to initialize it aside from the fact of the hardware changes. That was what I was trying to get across.
AESFTW
Exactly what I was saying as well.
