The PROGRAM menu on my M7300
ElroyJetson
I AM NOT YOUR TECH SUPPPORT.
DO NOT ASK ME FOR HELP PROGRAMMING YOUR RADIO. NO.
So what happens if I select PROGRAM on my M7300?
I'm kind of afraid to mess with that.
I think it has something to do with switching the radio between ECP and OTP protocols,
but I don't think this radio has OTP in it so I really need to know what'll happen if I choose to press that button.
And what happened to the GPS menu option that I swear was available the last time I had a P7300?
I can't even find that menu option in RPM 10B.
DisasterGuy
Maryland Shore
Program is used to put the radio into program mode if it doesn't automatically do so when read.
I have never seen a GPS menu option on a 7300 but none of ours have GPS boards in them.
Sent from my Pixel using Tapatalk
ElroyJetson
The GPS menu option on a portable enables the usage of the GPS data coming from a GPS speaker-mic. Which I don't have.
I definitely had a GPS menu option before. An earlier version of RPM, I think?
Regarding the PROGRAM menu, maybe I was thinking it's the menu that allows you to switch between
ECP and OTP modes, but if it's not that, then what is that menu?
TDR-94
I've tried using PROGRAM in the radio menu and it does absolutely nothing on any of my portables.It just results with the error boop tone.
ElroyJetson
That is one oddity that is always a characteristic of the GE-to-Harris radio family. Menu options can be enabled that have no function in that particular kind of radio, which will have a function in other radios supported by the same RPM/ProGrammer package.
kb4cvn
Silent Key
Nowhere near a paved road, away from the maddening
First of all, not all menu functions work on all radios.
Second some of the menu functions are dependent on the revision of firmware.
Third some of the older radios (M-RK, Orion, etc) also required a specific RAM size to support specific functions.
Example:
"FEATURES" in a M-RK or Orion radio...
It was supported only in 512k hardware radios, with Group 30 or later firmware.
"PROGRAM" & "GPS" shown below.
Note: "PROGRAM" only is supported on the Unity mobile and portable radios.
TDR-94
I've noticed that the HELP menu can sometimes indicate a radio model being supported, under the radio specific section,for a particular feature and then under a different search result for the same feature,indicate the same radio model 'not' being supported.
EDACS Priority one scan is an example. Only under one specific search for that function does RPM mention that the P7100 isn't support for scanning a conventional channel in conjunction with a P25T system set for Enh CC scan.
