What is Digital Wait Time?
Can someone please explain Digital wait time to me I’ve got mine set it for hundred milliseconds and still having trouble with picking up all transmission
Uniden scanners allow you to program conservatively. What I mean by this is that you can simply enter a frequency and Uniden will play it if the radio system is compatible. You do not have to enter in all system details such as the selective reception code, analog/digital, or modulation.
However, analog and digital radio systems are handled completely differently by the scanner.
In order to determine whether a signal is analog or digital, the scanner first passes the call to the digital decoder. If it says "hey, there is digital data here," then the scanner immediately plays the digital radio call. If there no digital data frames are decoded after a certain time, the radio assume "hey, this must be analog," and it then plays the analog audio call.
"Digital wait time" is the time period in which the radio monitors the signal to see if there is digital data. Honestly, it's really an "analog" wait time, because it only delays analog calls. Digital calls will play immediately.
So, what is important about this setting on a practical basis?
For however long the Digital Wait Time setting lasts, you will be that late to all analog calls. However, if it is too short, it is possible that the scanner could fail to detect a digital call.
Digital Wait Time is most important when you are scanning new frequencies and you don't know what type of system it is; for instance, when you use digital frequency search quick import.
To avoid this issue altogether, set the object to either analog or digital specifically, and then analog calls should play immediately (I'd set the Digital Wait Time to 0 on analog objects, just to be sure). Keep in mind though, the more liberal you are with programming your scanner for only specific things, you will hear less once things change.
I do not know if this relates to your reception problems, but the question was about explaining Digital Wait Time, so I figured I would do so.
