Motorola XPR 7550 Repeater Programming Issues
GTSECURITY
Bowling Green KY
I'm sorry if this has been posted about already but I have had no luck finding it in the search criteria for this particular radio and this issue.
To start off, I am posting on behalf of my company, a security company, and we are trying to program our Motorola XPR 7550 radios to work with a repeater setup in our local area of Warren County KY. We work with and assist law enforcement agencies in the area but do not have a repeater currently setup by us. The state granted us the use of their repeater system and the information is as follows
Frequency: 460.57500
Type: RM
Tone: 100.0 PL
Alpha Tag: WC EMA
Mode: FM
We are attempting to put our radios on the Warren County Emergency Management repeater system which is county wide, we have permission from the county to do so however we can't figure out how to program the radios with the 100.0 PL tone or any PL tone for that matter. The Motorola CPS version that we have doesn't have anything about PL tones in its descriptions. We came across a article that said the "Quick-Call II" or "Capacity Plus" is what we would use but we have no way of actually figuring out how to configure the radios because nobody in the county programs these radios. The current radios are sent off somewhere to be programmed but we have everything in house to do it. We just don't know how to configure the settings or put a PL tone into it. We have never programmed them with a PL tone before. We did have them on a repeater system and was able to program that just fine, we just don't know how to put PL tones in.
If anyone could help us with how to program the PL tone into the Motorola XPR 7550 using the CPS software we would appreciate the help.
Thanks in advance and again, sorry if this has already been answered somewhere.
mikewazowski
Staff member
Forums Manager
Oot and Aboot
Moved from the Amateur Radio forum as this has nothing to do with Amateur Radio.
N4KVE
PALM BEACH, FLORIDA
It's right there on the page with the freq's etc. Of course when you add a new channel, you have to make sure it's an analog ch. You can not convert a digital ch to analog.
TampaTyron
Beep Boop, Beep Boop
Phoenix, AZ
You may already be getting people offering help via Private Message. If you do not get resolution quickly, feel free to pm me your email address and I will help. This should take only a few minutes per radio. TT
mikewazowski
Staff member
Forums Manager
Oot and Aboot
He's only got one post so it will be a while yet before he can use PM's.
alcahuete
Antelope Acres, California
Set up your frequency like so. Make sure the squelch type is set to TPL, and then the TPL frequency of 100.0.
GTSECURITY
Bowling Green KY
XPR 7550 VHF programming
Hi everyone,
So if you haven't seen my other post on here, I'd like to say that I own a company in KY and we work with local law enforcement to assist them in day to day operations. We recently received permission to monitor and use local official radio channels and we were able to get the UHF channels set up (403.0000 and higher) but our radios won't allow us to program VHF channels in. We read the manual and it says we have the VHF, UHF, DMR, Analog combination model that allows us to program all those types in. Every time we try programming anything below 403.0000 it changes it back to 403.000.
Example: we setup a digital channel or analog channel and attempt to program in 157.6734 in the RX frequency but the second we click on anything else it changes it back to 403.0000.
We're using Bluetooth to program the radios and Motorola CPS version 13.5 I believe.
Any help would be greatly appreciated
Thank you!
KevinC
Other
Super Moderator
Home
The XPR7550 is not a multi-band radio. If it won't let you program below 403 MHz you have a UHF radio (403-512 I believe).
And I moved your question to your existing thread since it pertains to programming as well.
kayn1n32008
ØÆSØ
Sector 001
Kevin is correct. The XPR-7550 is a mono-band radio. Your radio covers 403-512MHz(520 can't remember exactly). The spec sheets show ALL bands, but each radio is only one of the available band segments
