Non-profit users of FRS / GMRS radio at 1.5W power
spareparts
spareparts
So here the question: A non-profit (Church, museum, school as examples) may or not use FRS/GMRS portable radios at 1.5W of power?
For background, the radio fleet is a mix of bubble pack radios and baofengs.
The subtleties of a 16 Chanel radio and what channels to use at what power level might be a bit much.
Reference / link to the CFR would be helpful.
nd5y
Wichita Falls, TX
Baofeng radios are not legal to use on FRS or GMRS because they are not Part 95 certified.
The FCC recently changed the rules so that common Part 95 certified FRS/GMRS dual-service bubble pack type 2 watt radios are reclassified as FRS and can be used without a GMRS license.
http://transition.fcc.gov/Daily_Releases/Daily_Business/2017/db0519/FCC-17-57A1.pdf
https://www.federalregister.gov/documents/2017/08/29/2017-17395/personal-radio-service-reform
Here is a table of bandwidth and power requirements for the new rules.
https://wiki.radioreference.com/index.php/FRS/GMRS_combined_channel_chart
spareparts
spareparts
Tom,
Baofeng are not type accepted (removable antenna issue) got it.
So a non-profit or business can now go out and purchase bubble pack radios and use them without a license on any of the 22 GMRS channels, provided the radio is smart enough to reduce power to 0.5W on channels 8-14
SP
SteveC0625
Order of the Golden Dino since 1972
Northville, NY (Fulton County)
So a non-profit or business can now go out and purchase bubble pack radios and use them without a license on any of the 22 GMRS channels, provided the radio is smart enough to reduce power to 0.5W on channels 8-14.
Anyone can use the FRS/GMRS (bubble-packs) radios at full power on 1-7 and 15-22 effective 9/28/2017. Doesn't matter if it's a business, a non-profit, or just plain folks. It's "license by rule" meaning that as long as they follow the rules, there's no formal license required.
All of the current bubble-packs will only do 0.5 watt on 8-14. There's no high power for them and that limitation is built into all of the radios.
FWIW, the FRS side was always legal for anyone to use including non-profits. Yeah, a lot of businesses including non-profits operated on the GMRS only channels at higher power all along. The FCC never did much if anything in the way of enforcement on that, and the new rules basically affirm that. It's just not something to fret about.
RFI-EMI-GUY
The Baofeng radios are specifically illegal for this use as they are not certified for Part 95 and have detachable antennas.
Sent from my SM-T350 using Tapatalk
RFI-EMI-GUY
Most non profit organizations are perfectly eligible for a part 90 business frequency and would be better served by using proper part 90 radio equipment.
They should up the wattage for FRS only and then nobody would be trying to get around the restrictions.
Why not make it a higher power?
There is no service in which people can communicate legally to each other freely that has a high power .
You can't even do it half duplex.
I do get a kick out of all the legal beagles, these frequencies barely ever get used here in New Jersey, they are dead frequencies.
GMRS I hear the repeater ID once and awhile.
FRS is dead.
Kids have top of the line cellphones.
RFI-EMI-GUY
FRS is dead.
It is illegal to modify an FRS radio for higher power. It is illegal to use a non certified radio for FRS. A non profit organization, can indeed obtain a part 90 license and use higher power equipment. It is surprising, to read yet another licensed amateur radio operator encouraging illegal operations in the Part 95 spectrum. Amateur radio operators go ballistic should one suggest using ham radio illegally. Hey why not, I live near a major metro area and there are dozens of ham repeaters that are unused.
power
They do that here in NJ, use ham illegally, It happens all the time.Goons with Baofengs make noises,etc on local repeaters.
If you stuck to one frequency on FRS and ran 5 watts instead of 2 watts I am sure nobody would notice is my point.
CB supposed to be 4 watts and how many CB's are peaked and tuned?
no high power service is why
The FCC just did that.
2 watts is about as useful/reliable as nothing.A step in the right direction but still unrealistic.
5 watts with a Baofeng are what people want.
Thats why they buy it, Amazon sells thousands of the UV5R and UV82.
They should allow the public to have a higher power free communications service is what I am saying so people don't illegally modify their devices is what I am saying.I'm not condoning anything.I do feel they should legalize a high power FRS. 25 watt mobile and 5 watt walkie talkie.
I am telling you the proof, look at CB, thats your proof that people Want higher power devices that work to reliably communicate.
The FCC and government won't allow people to ever have such a free service is fact.
Years have passed and it has never happened.
How to do it? Spread spectrum is an idea. Cordless phones have this technology.
swen_out_west
Upper Mojave,CA/NV
FRS is dead.
FRS only does not mean that that is the only thing on that spectrum of 467.xxx. FRS only referred to the fact that before today only FRS could use those actual channels at those specific power levels, and even then now with the new rules the ERP is still restricted so as not to cause problems.
Those channels straddle the repeater inputs of GMRS. Since GMRS is still authorized wideband, too high of power would definitely cause interference or even be picked up and re-transmitted if it happens to be the right PL.
kayn1n32008
ØÆSØ
Sector 001
You realize that the difference in distance you can talk between 2 watts and 5 watts is likely less than 50 meters. It's slightly over 3dB, right around half a S-unit...
scanningisfun
Which is also illegal, all day long.
So are you going to charge me with a felony?
Just saying, in the big scheme of things, everyone in this thread who is worked up over the legalities of using a Part 90 radio at 5 watts on FRS only frequencies should find something better to do. I'm not bothering anyone when I chose to do so.
