Will we ever be able to organized channels in a scan list ? As it is my scan list are a mess, channels go in random order I have no control over. This stinks big time !
Doesn't sound so EZ does it?Will we ever be able to organized channels in a scan list ? As it is my scan list are a mess, channels go in random order I have no control over. This stinks big time !
Huh???? You can sort Scanlists, Conventional Frequencies, Trunked Radio Systems.Will EZ Scan software ever be fixed ?
Simply click on the any of the Headers (Rec#, Alpha Tag, Frequency, Mode, Squelch, etc.....) to sort.
I won't argue with that basic sentiment.EZ Scan works great for me. I will take it any day over the 536's software...yuck.
Huh??? Just because you can sort in EZScan doesn't mean it's sorted in the radio when you write it. So, if I want to add an additional conventional channel to a scan list it goes on the end, there is no moving it around or putting it with the "other" similar channels.
So, if I ever want to browse the objects in the radio they are unorganized.
here in SC pal 800 has switched over to PAL P25 seems that the db is conflicting with the software when i import maybe 2 to 3 freq are missing from the DB/RR i do not even have import CC/VC only enabled so every time i update i have to go back check all freq make sure there added most the of the time theirs 1 or 2 that haven't been imported out of 20 or more sites and have to input them manually so frustrating
so importing 50+ sites 20 of them im going to have to add 2 or maybe 4 freq WTH
