kd5yuk
What exactly does a wildcard do and why do I need one? Do I need a wildcard for each talk group or just each scanlist?
A wildcard is basically like an ID Search for trunk systems. It'll display talkgroups you don't have in the scanner for a Certain trunk system. Personally I'd recommend having one for each trunk system you have.What exactly does a wildcard do and why do I need one? Do I need a wildcard for each talk group or just each scanlist?
You must have a wildcard to "search" for TGIDs. If you don't then your scanner will just SCAN the TGIDs that you have programmed.
I have a TRX-1 and I would like to find out exactly how to add a talk group to an existing trunks system I tried doing so but I do not know if it’s successful because I have yet to hear any communications can someone please help ? Also in the progress of trying to program a new tub group I’ve come across the word TGID wildcard I am still confused on what a wildcard is when I use the right arrow a bunch of numbers came up and then I entered the talk group ID and saved and named it was I doing this correctly ?
Thank you very much for confirming talk group programming the Whistler scanners looks like we did everything correctly I suppose the talk group we are listening to is just very inactive, thanks again at least we know we were doing something right
Nope - that's it. If you press SKIP during the "raw" wildcard hit, you'll only lock out the wildcard object.Hi,
Talking about wildcard, is there a possibility to quickly Skip or L/O a talkgroup found by a Wildcard object (other thant Menu -* Store Wildcard, and then wait for the scanner to stop on the new object)?
If we press Skip while on a wildcard group, it's the wildcard object that will be skipped.
It would be nice to have a way to do it quickly like the TG L/O function on the PSR-500 (if I remember correctly the name of this button...)
Thanks!
tikev
Since the TRX-2 has so many "banks", when looking for additional TG's I have one "bank" just for Wildcards. This way I can turn it on/off at will.
