Palisades mall security
KD2EUM
I’ve been trying to monitor the security frequency for the palisades mall and have had no traffic for a few weeks. Can anyone advise if they changed their frequency?
KD2EUM
Anyone else having problems receiving palisades mall security. I just get static
KD2EUM
Yes. I was even using close call feature. I would get the hit with the frequency and then static. I think they might have gone digital dmr
seagravebuff60
Well Known MRRS Hater
New York State
A BCD325P2 should pick up a DMR system.. have you upgraded the firmware on the scanner to the latest?
KD2EUM
That’s a good question. Do u by any chance know the latest 325p2 software version? Thnx for the response by the way
seagravebuff60
New York State
No Problem. The latest firmware should be 1.07.09. It was released on 9/67/17.
BCD325P2FirmwareUpdate < UnidenMan4 < TWiki Click On the top link witch will download the update program, Unzip it and install it once finished find the application select the scanner model (BCD325P2) and the latest firmware (1.07.09) and make sure you scanner is plugged into your computer and that will update it. Let me know if you have any troubles and im glad to help. Let us know if there still is any static on the security frequency.
KD2EUM
I updated. Now off to the mall to see if it works. Do u recommend any settings on the scanner to make sure close call works?
seagravebuff60
New York State
I have a BCD325P2, I could say to make sure you have your close call settings on and once the mall security transmits the close call should pick them up with their mode and tone, also make sure you have the mall frequency programmed in just as kind of like a backup if you know what i mean.
KD2EUM
Do u know of an inexpensive ht like a baofeng or the yaesu ft70d that can monitor that frequency. Thnx in advance
KD2EUM
I didn&#8217;t make it there yet. I updated the firmware with no problems however I think I have to purchase the dmr upgrade from Uniden to recieve that frequency using close call. Can u recommend an inexpensive ht that can be programmed to recieve that dmr frequency. I was looking into the tyt 530? Thnx
