Flexible gooseneck lamp
bobsav21
Maine / Florida
Does anyone know where I might find a flexible gooseneck lamp that uses 12VDC.
I'm looking for something approx 12" or so and similar to the one's I've seen mounted in patrol cars
clipboard or computer area.
Bob
jtech48
OVB
bobsav21
Maine / Florida
That Hella one looks good, the other one is way out of my price range. :)
Bob
Maplights is the magic word that I couldn't' think of
Thanks again
jtech48
OVB
It's nice and comes with both a white light cover and a red light one. It is halogen so it can get hot but thats the only con if it even matters, i've never had a problem. Very easy to install, it took me maybe 15 mins, and thats because the wires that come built in are very short and I had to extend them
wa8pyr
Technischer Guru
Staff member
Lead Database Admin
Ohio
There's this type which I have installed in my truck and works perfect off of the aux fuse block https://www.amazon.com/HELLA-004532171-Flexible-Reading-Housing/dp/B0000AYAEO
Sho-Me also makes one which is more similar to the maplights that are on the Havis consoles. https://www.chiefsupply.com/sho-me-18-led-map-light-hardwire.html
Both brands also sell the lights with a 12v cigarette lighter end if you didn't want to hardwire.
I have the Havis Shields C-MAP-T 12" halogen model, which I paid $5 for at a hamfest, including the two 12v "accessory power ports." Very handy gadget, although I removed the 2-pin halogen bulb on mine and put in a 2-pin LED replacement so it would run cooler. Works like a champ.
Havis Shields C-MAP-T Gooseneck Red White Map Light Lamp w/2 12V Outlets
There are several of these on eBay right now, with or without the power ports. A search for "Havis Shields gooseneck" brought up several.
LitteLite makes a few different designs, even those branded by other companies:
Littlite Task Lights Flexible Gooseneck LED 12V Adjustable Work
I've used these off an on for many years.
The halogen ones can get quite hot.
The halogen ones also have (or at least did) a plastic red shield that slid over the lamp for night use. Problem I've run into was that the plastic either got lost or damaged.
If you are buying new, I'd recommend the LED's just to eliminate the red plastic.
