Milwaukee County OASIS Digital Trunked Radio System
mkescan
Milwaukee
Thought it would be a good idea to Start a new thread for just Milwaukee County. Might be some Talkgroup,User & other confusion on the Milwaukee County & Waukesha County thread when they get more active with users.
Looks like Milwaukee County Transit Buses cut over, but for some reason Supervisors & Security are still using Analog.
Here is what I have for EMS, Fire, Police, Sheriff. Sounds like only North Shore Fire cut over.
Airport Fire Primary - 2071 (Up & Down Patch)
Cudahy Fire Primary - 2061 (Full Time Patch)
Franklin Fire Primary - 2091 (Up & Down Patch)
Milwaukee County IFERN 1 - 2059 (Full Time?)
Milwaukee County EMS Com 01 - 2007 (Up & Down Patch)
Milwaukee County EMS Com 02 - 2009 (Up & Down Patch)
Milwaukee County EMS Com 03 - 2011 (Up & Down Patch)
Milwaukee County EMS Com 04 - 2013 (Up & Down Patch)
Milwaukee County EMS Com 05 - 2015 (Up & Down Patch)
Milwaukee County EMS Com 06 - 2017 (Up & Down Patch)
Milwaukee County EMS Com 07 - 2019 (Up & Down Patch)
Milwaukee County EMS Com 08 - 2021 (Up & Down Patch)
Milwaukee County EMS Com 09 - 2023 (EMS Com Base) (Full Time Patch)
Milwaukee County EMS Com 10 - 2025 (County EMS) (Full Time Patch?)
Milwaukee County Firecom 1 - 2053 (Full Time Patch)
Milwaukee County Firecom 2 - 2055 (Up & Down Patch)
Milwaukee County Firecom 3 - 2057 (Up & Down Patch)
Milwaukee County Firecom 4 - 2181 (Up & Down Patch)
Milwaukee County Firecom 5 - 2183 (Up & Down Patch)
North Shore Fire Primary - 2081 (Full Time Patch)
North Shore Fire Tac 2 - 2083 (Full Time Patch)
Oak Creek - St Francis Fire Primary - 2131 (Full Time Patch)
Oak Creek - St Francis Page - 2151 (Full Time Patch)
South Milwaukee Fire Primary - 2141 (Full Time Patch)
Wauwatosa Fire Primary - 2161 (Up & Down Patch)
West Allis Fire Primary - 2171 (Up & Down Patch)
Cudahy Police - 1149 (Full Time Patch)
Oak Creek Police - 1053 (Full Time Patch)
South Milwaukee Police - 1129 (Full Time Patch)
St Francis Police - 1167 (Full Time Patch)
Milwaukee County Sheriff Patrol 1 - 1401 (Full Time Patch)
Milwaukee County Sheriff 2 Law Call - 1403 (Full Time Patch)
Milwaukee County Sheriff Patrol 3 1405 (Full Time Patch)
Milwaukee County Sheriff Courts - 1407 (Full Time Patch)
Milwaukee County Sheriff Airport - 1427 (Full Time Patch)
Milwaukee County Sheriff Institutions - 1431 (Full Time Patch)
mkescan
Milwaukee
Greendale - Hales Corners Police Primary - 2397 (Full Time Patch)
Sounds like Hales Corners is all Digital.
Handyxena
Oasis
When setting up oasis do you need to set the frequencies on 2 different banks or can you just put all the control channels into one
mkescan
Milwaukee
Milwaukee County Fire Update.
Airport Fire Primary - 2071 (Up only when Digital Radio is monitoring or using Talkgroup)
Franklin Fire Primary - 2091 (Up only when Digital Radio is monitoring or using Talkgroup)
Greendale - Hales Corners Fire Primary - 2121
Milwaukee County IFERN 1 - 2059 (Up only when Digital Radio is monitoring or using Talkgroup??)
Milwaukee County Fire Call - 2051 (This is Firecom 1 on Analog)
Milwaukee County Fire 1B - 2053 (Up only when Digital Radio is monitoring or using Talkgroup)
Milwaukee County Fire 2B - 2055 (Up only when Digital Radio is monitoring or using Talkgroup)
Milwaukee County Fire 3B - 2057 (Up only when Digital Radio is monitoring or using Talkgroup)
Milwaukee County Fire 4B - 2181 (Up only when Digital Radio is monitoring or using Talkgroup)
Milwaukee County Fire 5B - 2183 (Up only when Digital Radio is monitoring or using Talkgroup)
North Shore Fire Tac 3 - 2085
South Milwaukee Fire Primary - 2141 ((Up only when Digital Radio is monitoring or using Talkgroup)
Wauwatosa Fire Primary - 2161 (Up only when Digital Radio is monitoring or using Talkgroup ??)
West Allis Fire Primary - 2171 (Up only when Digital Radio is monitoring or using Talkgroup ??)
Waukesha / Milwaukee County
mkescan: Did you adjust the P25 LP Filter, Adjustment Mode, Adjust Level settings by chance? I pick up transmissions but they are garbled.
mkescan
Milwaukee
I didn't notice a difference, maybe I was doing it wrong. But noticed just playing with antenna, up down side to side made a big difference, for Waukesha County. Lock on Control Ch, or on a talkgroup you have programed, and watch the Signal bars while doing it.
yosmiths53172
South Milwaukee, Wi
I have a Radios Shack Pro106 that I have been using and it seems that South Milwaukee Police have made a change. I can no longer pick them up on my scanner. I know they were checking into a change after the problems the system had this summer. Do I need to reprogram??? Any help would be great.
I still pick up the other cities in the area...
mkescan
Milwaukee
Wow, looks like they are the 1st to cut over to OASIS, just heard them on OASIS, nothing on Analog
yosmiths53172
South Milwaukee, Wi
I have and used WIN500 for the programming, but I don't see any changes the frequencies for South Milwaukee. I am a rookie at this stuff, so I am not sure how to make some of these changes either. is there just a setting on the scanner to switch that channel to P25??
prowisscan
Milwaukee, WI
Yes, the PRO106 will work with OASIS. I would recommend reviewing the owners manual to set up. It's pretty much the same set up as the analog system; you only have to make sure that you set the trunk system to P25 rather than Motorola. You could theoretically change the existing Motorola system to OASIS by changing the setting from Motorola to P25 and to change the control channels that the scanner will monitor for activity; but it would be easier to just set up a new trunk system on your radio.
yosmiths53172
South Milwaukee, Wi
I think got it figured out last night, but I have a couple questions. When I went into the bank I had set up for South Milwaukee, only a couple of the frequencies on the list where attached to that bank, so enter the missing ones. Not sure if I should have done that?? And they went from 6 talk groups to one?? Does that make sense?? But I do hear them and the sounds is grabbled at times. Not sure if it is the system or is there some type of adjustment that I need to make on the scanner..
Thanks for the help...
KD4YGG
Program in the main and alternate control channel frequencies for the Milwaukee County site. They are the ones in red or blue with an ‘a’ or ‘d’ next to the frequency.
As for the talk groups, several area members are working on figuring them out and confirm usage.
It appears if you take the old Motorola system talk groups and divide by 16, you SHOULD have the corresponding talk groups for the new digital OASIS system - at least for Milwaukee County this appears to be the case.
luv2ride_hd
Morris IL
Hey guys I used to be into scanning a long time ago (20yrs) and am getting back into it. Wow have things changed. Ive been reading and sorting things out the best I can. My scanner arrives today (uniden bhp436) I wont have an issue programing it with my comp, at least I dont think so :)
I'm in Tosa & of course would like to listen to them. Doesnt seem to be an issue, Milwaukee police however seems to be digital if I read this correctly. Does this mean its a no go for scanning?
