Hello,
I am having an issue with programming my XTS5000 Model I UHF to Non-Affiliate scan a P25 Phase I Trunking System. I have programmed many radios in the past to Non-Affiliate for SmartZone. I am using the Hidden Talkgroup Method. The issue is that when I am done programming the radio and write back to it, it plays a tone every few seconds, very similar to when you press the PTT on a RX only channel. I have never had this issue when programming SmartZone. I do not believe it is the Out of Range Indicator, since I have that turned off in the CPS settings. Has anybody ever had this issue?
Thank You
Thank You
