Motorola XPR 5550 Microphone.
dixie729
Daviess Co., KY
Here is the million dollar question.
Are the programming cables the same. XPR and XTL.
Anybody have any issues with the USB cable?
Sent from my XT1097 using Tapatalk
Project25_MASTR
Millennial Graying OBT Guy
Texas
The real answer to both questions is it is entirely dependent on how the XTL you are referencing is configured and whether or not your version of the GUCI cable is serial or USB.
If you've got an XTL with a W series head and is a mid-power unit, the answer to both questions is no. If you've got a high power XTL with a W series head, then the programming cables are the same but the microphones are not. If you have O/M series heads on your XTLs, then yes to both.
This is all true if you have the USB version of the cable.
dixie729
Daviess Co., KY
Referring to the front facing microphone port of the XPR being the same front facing port as the XTL.
I see the ports look almost identical, but I figured there was something big M did that made the 2 ports non compatible with each other as far as programming cables and microphones.
I've always used serial port programming cables, but could not find one for the 5550 version of the XPR.
N4KVE
PALM BEACH, FLORIDA
And in my case, my XTL's are all front mount O series heads. What does give me troubles is the rear mount serial cable.
dixie729
Daviess Co., KY
I'd rather not have to unmount my radio to program it either. I'll stick to the front mount
Project25_MASTR
Texas
My VHF XTL is a high power with a W9 (upgrading to a O5 in the next few months). My UHF and 7/800 MHz XTL's are O5 dash mounts. I've never seen the rear serial cable, all of the service cables I have for the rear connector are USB. Do have both serial and USB GUCI cables though.
dixie729
Daviess Co., KY
Wiscomm had the front facing port programming cable with the serial connection. APX, XTL and MOTOTRBO models listed. But the 5550 was not listed for the XPR so I didn't know if it was something to do with that model XPR.
I've never had a usb programming cable. Always been deemed to the serial ports. Some have good luck with them, others have the worst luck, I heard that some here. But I may just jump in the usb cable.
Any particular OS of Windows it doesn't like or seems to work best with? I've still got the old XP laptop reading and writing like crazy. Haha.
