Bcd436, DSDPlus showing different info.
dave3825
Suffolk County NY
I am going to ask here as this involves fed radio, tg and rid, and DSDPlus and BCD436HP.
There was a roll call this morning and I logged it with Proscan. Dsdplus event file also logged this. When the person conducting the roll call calls out to a party to complete the radio check, dsd lists one radio id, and the 436 lists a different one. Dsd also listed every tg as tg1. The 436 did mostly the same but on some, it would display the 4095 tg. I lined the 2 logs up side by side. The radio id's for the agencies checking in seemed fine, so it's just the main radio conducting the roll call that exhibits this.
Any ideas?
bravo14
Polk County FL
How much signal bar are you getting? I notice even on full signal bars I see different TG with the same voice and rid are the same. I wonder if the new Firm Ware still has the bug in it. I run DSDPlus it runs fine.
ecps92
Taxachusetts
Generally the Dispatch Console uses 4095 as a FLEET CALL or in Trunking language the ATG [Announcement Talk Group] and the users are on TG 1
Unknown if the Dispatch Console is a Base Station or a Real Console from one of the Mega Centers, which is generally where I have only seen the 4095 used
Any ideas?
dave3825
Suffolk County NY
Scanner had full bars.
Announcement Talk Group So should dsd pick that up? And what could be a reason the 436 does not pick it up each time?
ecps92
Taxachusetts
Out of my realm with DSD, however it could be the user Quick Keyed vs letting the repeater unkey, or the software wasn't reading the data fast enough...
slicerwizard
Toronto, Ontario
I've seen this on a few conventional PS P25 repeaters. The dispatcher's HDUs say TG 4095, but everyone's LDU1s say TG 1. I'd say the calls are on TG 1.
(Dispatcher)
HDU: MFID: 0 TG: 4095
HDU: MI: 77 D6 9C 7F 17 CC FA E5 00 KID: 0001 AlgID: AA - ADP
Sync:+P25p1 NAC:561 LDU1
Muting encrypted voice
LSD: 10011100 11100110
[E] Channel Group & User: Tgt=1 Src=2 <--- Dispatcher
Sync:+P25p1 NAC:561 LDU2
LSD: 11110011 01111101
LDU2 ES: MI: 29 7A 8F 0B 06 89 B2 D4 FA KID: 0001 AlgID: AA - ADP
(Mobile)
HDU: MFID: 0 TG: 1
HDU: MI: C9 21 F6 FF BF F8 F5 27 00 KID: 0001 AlgID: AA - ADP
LSD: 10101000 11100111
[E] Channel Group & User: Tgt=1 Src=140 <--- Mobile
LSD: 10001100 00110100
LDU2 ES: MI: DD F6 2E 21 E9 75 98 0E 00 KID: 0001 AlgID: AA - ADP
If it misses the HDU, it's not going to see 4095.
All of the info is in the console log - check it out.
ThePagerGeek
4095 is the default TGID in Motorola DIUs. (Links the console to the system)
Fairly common to see that TGID from the console in a conventional system since it really doesn't matter in the end.
