Xtva external speaker and hhch problems
ki6qfi
Orange
I just got a hhch and am external PAS speaker for my xtva, the kit number for the xtva is ntn1607f and the antenna port as well as the charging circuit work great but when I plug in the hhch and the speaker nothing happens, no audio out of the speaker and no display or anything on the hhch, the radio does not go into remote mode like it's supposed to, I've been trying to figure out what I did wrong or if I missed something in the cps, I've already assigned the hhch button functions in the cps and still nothing works, any help will be very appreciated, thanks.
Sent from my SM-G920P using Tapatalk
dubs0980
What radio? Firmware version? The HHCH is a PLN7737 or something else? You mentioned the antenna port works so I assume that means you have the RF adapter on the radio?
marcotor
I ♥ÆS Ø
Sunny SoCal
Depending on the XTVA, you may need to reset it:
To re-initialize the microprocessor, disconnect power and remove radio. On the DB-25 connector, short pins 21 and 23 together, and also short 1 and 10 together (Do not connect them all together). With the pins shorted apply power to XTVA for at least 10 seconds. Remove the power source and jumpers. Power the XTVA back up and insert a radio. The XTVA should display the following if successful:
Charge LED:..Single Orange Flash then changes to Solid Red
TX LED:.........Single Orange Flash then switches off
Note: TX LED is on the left, Charge LED is on the right.
ki6qfi
Orange
Radio is XTS 5000 model 2 and the firmware on it is 20.05.09 I believe and yes I have an rf adapter on it, I have 3 rf adapters, one for each of my 5000's, vhf, uhf, and 7/800.
ki6qfi
Orange
And the hhch is indeed a PLN7737.
ki6qfi
Orange
I've tried resetting both units I have and nothing changed so I'm completely stumped, I just think the internal components may be bad, thanks anyways.
dubs0980
I'll be weirded out if this works but someone just helped me with a speaker mic issue. I wasn't receiving audio and tried cleaning the contacts on the radio with and eraser but no joy. He still recommended cleaning them so I gently scraped with a steel pick and it worked. They looked prefect before but apparently there was something on them still. I had two xts3ks that were doing this and I thought it was board/flex related and I shorted something. 3 radios with dirty contacts would be a stretch but worth a try before you crack it open or toss it.
