Hi all,
First post here and sorry to drag up an old thread.
I have a 200xlt that I bought new as a kid and it's still in amazing condition. Of course the battery back needs some attention. I discovered while attempting to charge the nicad pack that after 10 hours it was what I would call extremely hot.
I took it apart as the plan was to replace the cells. Before I went ahead and replaced the cells I wanted to look closer at the charging circuit board in the battery back to see if anything was obviously damaged with the high temp seen earlier. Visually it looked ok, except for the larger blue resistor. The legs of which look dark and corroded. I connected the wall wart and tested the voltage at the regulator. Input voltage from the wall wart is 18vdc, regulator is passing 10vdc to the battery pack. Looks good from what I can tell. I also discovered that the blue resistor may have had a cold solider joint. Unfortunately, and I'll assume from heat the color code is all but gone except what looks like brown as the first color and gold as the last.
So my question is, does anyone know what the value of this resistor is supposed to be? I've searched high and low for a picture or a schematic to figure it out but I've been unsuccessful, and I'd really like to get the old gem working again.
Any help would be greatly appreciated.
