Newbie looking for help
Tat2guy
Hi I’m new to this . I just bought 2. Beofang uv-5R. I want to use them for hunting and while playing airsoft
Can someone tell /show me the proper /legal frequencies that I can use? I mainly hunt in kemptville and lanark. Watson’s corners.
KK4JUG
GA
Probably none without a license. They're not certified for FRS; they're too powerful for MURS.
You probably should have bought FRS radios. I think they're allowed 2 watts now.
N8IAA
Fortunately, GA
Always best to state where you're from. What's legal/illegal in Ontario Canada is going to be different than in the US.
Larry
Use MURS, GMRS or FRS frequencies. A simple search of those will bring them up so you can program them.
Sent from my Motorola G5+
N8IAA
Fortunately, GA
Larry
Has anyone bothered to read my post?? He's from CANADA. Not the US...........
Whatever you post about regulations here are not necessarily true there.
Use of VHF in Canada is not the same as here.
Larry
mikewazowski
Staff member
Forums Manager
Oot and Aboot
Larry
Thanks Larry. I've detected a bunch of off-topic posts which have nothing to do with the OP's situation.
teufler
ST PETERS, MISSOURI
here is some links to license free operations in Canada.https://www.ic.gc.ca/eic/site/smt-gst.nsf/eng/sf08655.html
https://en.wikipedia.org/wiki/General_Mobile_Radio_Service This talks about usage in Canada.
Multi-Use Radio Service Frequency Table Industry Canada regulates what you can do on Murs frequencies and the equipment. How closely this is monitored, I don't know. You would have to program your radios to 2 watts max, set for 12.5, and do not use the radio with an external antenna. Radio usual have to be certified for where they are used. Realistically, if you keep the radio to the max power of 2 watts, you should be okay, though the radios may not meet the "standards". Worst case is that the radios did not cost much, so you are not out much money. If you become an ham radio operator, these radios are a good starter.
gvodvarka
Ontario, Ca.
Beofang uv-5R
I would use VHF MURS frequencies do not require a license. Also VHF will work better around hills and outside. Gary
