I've been using SDR# for some time now trying HDSDR. When using the same RTL type USB receiver and antenna I'm getting much lower signal strength using HDSDR. I have the gain settings and PPM adjusted exactly as it is in SDR# but signal strength remains very low. I'm testing on the local VHF weather broadcast as it is a good reference station to tune these devices up on and test them.
The carrier signal strength on HDSDR is 40-50 dbm lower than using SDR# as is the noise floor.
I'm guessing I'm missing something in the settings somewhere. Been messing around with it for 2 days off and on and can't figure it out.
Also, is there a way to make the band scope section of the display larger? Can't figure that out either.
Any assistance appreciated.
