XG25p stuck in PERSDATA ERR 500
rescue674aa
I’m an idiot
I have a XG25p I wrote to the radio using RPM10B and it has R02B16 on the radio..I guessing it’s not compatible with the software or how you downgrade the Radio or get it back to where it was?
ElroyJetson
I AM NOT YOUR TECH SUPPPORT.
DO NOT ASK ME FOR HELP PROGRAMMING YOUR RADIO. NO.
RPM should have given you a message indicating incompatible firmware if that was the case.
A persdata error means there's something in the personality that isn't compatible with the firmware in the radio. This can happen if you were to, for example, attempt to stuff a fully featured codeplug from a totally whored-out P7300 into a totally different radio like the XG25 without any edits.
Roll back to the original file the radio came with. You did save it, I hope?
If not, create a new file for that radio from RPM and make it with just a single conventional analog channel and send it to the radio. That should remove the error.
Now you start adding system data which is easy and quick enough with RPM if your sets data is all global. Save and write the radio and check for errors. No errors? Add more. Repeat until you find out what part of the programming causes the problem.
And the features in the radio may give you a clue.
For example, maybe you're trying to enable encryption and that feature's not present.
Or you are trying to put P25 data into the radio without that feature.
Harris radios don't error check like Motorola radios do. Motorola CPS is very grumpy about those things
but it also tells you exactly what the problem is.
But a Harris radio just lets you dump anything into it and then YOU have to figure out why it's not working right.
emtLarmy15
Pocomoke City, MD
Yeah gotta put a new personality into the radio. My xg75p did the same thing (months after putting the profile in no less) and when we tried to recover the profile from the radio it kept causing RPM to shutdown. Blasted a new profile in it and it worked just fine. Never did figure out what was wrong in the old profile because we didn’t honestly care to because it was only a test profile with a bunch of different things in it
rescue674aa
I’m an idiot
I did blast a new file in it..still didn’t like it
emtLarmy15
Pocomoke City, MD
Do you know if the new file worked in it before? I guess I left that out. We put back in a profile that was previously known to work on the rwdio
rescue674aa
I’m an idiot
No I just wrote it one from a 7300
rescue674aa
I’m an idiot
Burnapp and bootapp loaded fine..I just need to find a firmware that’s compatible with RPM10B
rescue674aa
I’m an idiot
May just be the wrong version bootapp or XGP code
kb4cvn
Silent Key
Nowhere near a paved road, away from the maddening
Harris TSM 39-01: Rev A hardware XG -25P ’s will be become inoperative if re-fla
TSM 39-01: Rev A hardware XG-25P’s will be become inoperative if re-flashed with earlier radio firmware.
The XG-25P Rev A portable can be identified by the part numbers shown in Table 1. The radio will be loaded with XLP R03A29 (or later) and BurnApp 13D (or later) as stated in XLP Software Release Notes 14221-1800-8000 Rev J (or later). **DO NOT** reflash this radio to earlier BurnApp or radio firmware. Failure to follow the release notes instructions will cause the radio to become permanently inoperable.
rescue674aa
I’m an idiot
Still having issues? If so message me, I can load the current code but you will need RPM 14 or RPM2 to program it
No it’s been done and over with and not losing the ability for RPM 10b thanks anyways
