Cap+ Emergency
hamtrektng
Plymouth, UK
Just wondered if anyone has come across a talkgroup for Emergency Calls on a Capacity Plus system. I that on a Hytera XPT system they use the default talkgroup 250 for Emergency Calls
Your feedback is welcomed
N1GTL
CT
In MotoTRBO it's referred to as ALL CALL and it is TGID 255. It's not an "emergency" per se; it just transmits across all talk groups.
nd5y
Wichita Falls, TX
Does this work the same way on a MotoTRBO conventional repeater?
I found one that DSD+ shows as "Emergency" when TG 255 is active. I heard one of the users mention "this will key up all the radios". I don't know if it was a channel or emergency button they were using.
KG4INW
Midlothian, VA
Yes, ALL CALL can work conventionally as well. However, it would only go out over one particular time slot/color code combination at a time.
N1GTL
CT
If by conventional you mean digital but not trunked, yes (sort of). If you assign 3 talk groups to a time slot, talking on the ALL CALL will get to all the talk groups on that time slot. It WILL NOT transmit anything to the second time slot.
nd5y
Wichita Falls, TX
This is a non-trunked stand alone repeater. So far I have seen two other talkgroups. The main TG is on one time slot and 255 and the seldom-used TG are on the other time slot. I don't know if there are other TGs.
So you guys are saying it's not possible for the hand helds to monitor both time slots for All Calls?
KG4INW
Midlothian, VA
Correct, subscriber units can only monitor one slot at a time. ALL CALL is simply a way to have everyone unmute to your traffic, regardless of what Talkgroup you're currently on/have programmed in your assigned RX group list.
CanesFan95
FL
What about receive? If you're radio is on 255, will that make it promiscuous and you'll hear all group calls on the slot?
