The recommended procedure is to read the data you want from the (scanner a.) card with the version of E-Z Scan you use for the scanner you want to program (scanner b.), then use the "restore defaults" option. Then put in any custom settings you use for scanner b., write the data to that card, and go. There is some variance between models so this helps to get things dialed in.
