I recently upgraded from an FT-817 to an Elecraft KX3 with the built-in tuner option. I'm heading down to the Pigeon Forge area for a vacation soon and plan to take my radio with me since we'll be pretty high up. I have been using an inverted-vee dipole at 25 feet at home for the last few years and it's worked out great. I want to use something similar at the cabin without having to take my current one down.
I found some cheap pre-made dipole antennas on ebay for different bands. My goal is to try out 6 and 10 meters if possible, since I've always wanted to get on those bands and never had much luck due to limited time on the radio and bad propagation. But I'd also like to get on 15, 17 and 20 while I'm there, and will likely spend more time there. The cabin is two-story with full balconies on each floor. I was thinking of either a shorter, horizontal dipole on the top level or an inverted-vee mounted at the center of the top running the ends to the outer edges of the bottom level.
Which would probably yield better results, an inverted-vee or a horizontal dipole? Also, would a full-wave or half-wave be recommended? Would a 15-meter antenna be a good bet with the tuner? Thanks for any suggestions...
