Cdm1550
srfd3101
When I take radio out of scan mode it stays on channel it stopped on . I was trying to revert to priority channel is there a check box I am missing in the programming somewhere ??
W5KVV
S.E. Oklahoma
I've never had the pleasure of owning a 1550, but for my 1250 I would do that like so:
Open CPS>>>Read radio>>>>Radio Configuration>>>>Scan>>>Un-check Revert Scan
That way if you leave the radio parked on your priority channel & hit scan, when you bring the radio out of scan it'll revert to the channel you started scanning from. i.e. your priority channel.
Let one of the Waris Wizards chime in. They may know a better solution. Some of these guys know the CDM radios inside & out.
K2NEC
So I am not sure how your radio is programmed however I have never had that problem. Is there any way you could send me your codeplug and I could take a look?
SteveC0625
Order of the Golden Dino since 1972
Northville, NY (Fulton County)
For the purposes of this conversation, there's not an appreciable difference between the 1250 and the 1550. I have both and actually prefer the CDM1250.
I have Revert Scan checked on all of my radios. However in Scan List --> Tx Configuration I have the Designated Tx Channel set for Selected. With these two settings, the radio performs as the OP wants. OP, you can easily learn more about these things by using the F1 help file when selected on a particular feature unless you are using Win10 which won't display the help files. It's a Windows thing, not a Motorola thing.
