TXFirefighter112
Whenever I start running scannercast it freezes up and has to be shut down. I open it, hit the Login to RR & Get Config and then Start Broadcast. As soon as the status at the bottom says "running" I get a windows error message saying
So I can only open this program to close it again.
Immediately prior to this I had received a report that the audio was unintelligible, but attempting to correct that caused there to be no audio whatsoever. I undid the steps taken, but still had no audio whatsoever. I've rebooted both the computer and scanner twice.
Scanner info is Uniden BCD996P2, connected to PC w/ USB for data & 3.5mm stereo connector to the REC jack on the back of the scanner running to 3.5mm Line-In jack on back of computer.
Computer is running Windows 7 Home Premium 64-Bit, real-tek audio. No other devices or programs are using any sound devices or any related programs at all right now.
K1PGV's ScannerCast has stopped working
Checking for solution
A problem caused the program to stop working correctly. Windows will close the program and notify you if a solution is available.
