so if i run two dongles will they both work on sdr sharp. most of the you tube stuff i have looked at does not show two dongles, so what i am saying is how are they configured
This is complicated in the setup. The first dongle needs to be set up as a monitor on the control channel. You will know you have this right if you have Unitrunker (free) tracking and providing TGID, radio ID data, and correct voice frequency information.
The second dongle needs to be set up differently, and in effect slaved to the first dongle so it is being directed to proper voice frequencies by the control channel dongle so it can follow conversations.
While I regularly use the 1 dongle and Unitrunker setup, I have enough scanners I never bothered trying the second dongle setup, which is more complicated. Unless the system is a protocol that the scanner won't decode and SDR will, I would stay with scanner for audio, but it's a personal decision. SDR can decode some protocols that the scanner might not, such as DMR or others.
There are some threads here that discuss these specific SDR dongle double setup configurations a lot further, much more than I could provide here.
536/436/ws1095/996p2/996xt/325p2/396xt/psr800/396t/HP-1/HP-2 & others
