fonestar
I came by an older HT1000 that was going to be recycled by a client. The battery is toast but the handheld looks to be in very good shape cosmetically.
I know that others have posted hundreds of the same questions about programming the HT1000 so I will start by saying:
* Yes I am attempting to program from DOS, not from Windows or a DOS emulator
* Yes I am using a vintage Compaq laptop with a real Serial Port, I believe the CPU is 100 MHz
* Yes I am using authentic Motorola HT1000 programming cable
* Yes I have checked in the computer BIOS to make sure Serial port COM1 is enabled
* I am not sure the manufacture of the RIB box, it is a generic one from eBay I got a few years ago
* It has a brand new 9V battery in it
No matter what I try, the RSS software throws up a "Trouble with COM port..." message when I try and read the radio. I never see the DATA light on the RIB box go red or even flicker. Now I am powering the radio with an external power source set for 7.5V and current-limiting. I can also verify that the HT1000 is transmitting because I have a RF meter beside it. The DOS and RSS is being run from floppy disk A: drive.
Any other ideas of things to look for? I don't want to spend the money on new batteries for this 20+ year old radio if I can't program frequencies into it.
