TK-790/TK-890 Dual Band Question
car5le
Northwestern Montana
Here's what I have. TK-790/TK-890 Dual Band with single Control Head. Both radios are the standard lower power versions.
I want to replace the standard TK-790 with the TK-790H high power version. Does anyone know if this can be done by simply replacing the radios, or is there something that needs to be done to the TK-790H before it can be swapped out?
Thanks!
There are some chip resistors that need to be changed/removed it the RF deck to make it work with the control head. Too much to type it all out here. If you PM me with your e-mail address, I can send you the document.
mrweather
It depends which drawer is Radio 1 and which is Radio 2.
Also need to make sure the firmware versions are the same for both drawers or you may run into other issues.
car5le
Thanks. I ended up taking the dual band out and going specifically with the 790H. There is no UHF stuff where I moved to, except for amateur. And I have a separate radio for that.
