You would have to be with in close vicinity of the radio, it would keep changing and you would hear it much better monitoring the system.
Yes this is a site for monitoring radios, and most of us also have a vested interest in making sure the systems do not get interfered with. This is very little use or benefit to monitoring the input freqs on the system. The question you asked is one the usually sets off flags when being asked. If you understand the P25 standard, you can figure out all the input channels
You are not the radio police. I found them and here they are-
(157.2250/161.8250 MHz, 157.2375/161.8375 MHz, 157.2500/161.8500 MHz, 157.2625/161.8625 MHz, 157.2750/161.8750 MHz, 157.2875/161.8875 MHz, 157.3000/161.9000 MHz, 157.3125/161.9125 MHz, 157.3250/161.9250 MHz, 157.3375/161.9375 MHz, 157.3500/161.9500 MHz, and 157.4000/162.0000 MHz
157.2000/161.8000 MHz, 157.2125/161.8125 MHz, 157.3625/161.9625 MHz, 157.3750/161.9750 MHz, and 157.3875/161.9875 MHz
I am not sure why nobody has listed this in the DB. but I will try.
