each time I do the "Monday Update" on the the HP-1, I end up duplicating everything already in the scanner. On the other hand, it does not duplicate entries on the BCD536hp. Any ideas on how to correct the problem? Thank you for your time
sentinel pgm >UPDATE>UPDATE MASTER HP DATABASE>OK
remove USB cable - scanner reboots
connect USB cable - select Mass Storeage
Sentinel pgm > HOME PATROL>WRITE TO HOME PATROL >FORCE WRITE FULL DATA BASE >
remove USB cable > scanner reboots
