kd5yuk
Anyone have any information on why Bowie County dropped the P25 Phase II and joined the GATRRS (13e) Zone 2?
What scanner are you using?It was on the old Bi-State Information TRS. It was then upgraded to use the Bi-State P25 TRS system https://www.radioreference.com/apps/db/?sid=9342 which was removed a few days ago and labeled as deprecated. At the time, TAPD/TAFD would use the AWIN system and TTPD and TTFD would use a "DPS" radio system. Now I'm being told that they're using GATTRS by a Hooks PD officer with no clue about the new system. Question is, how are they using the new system with no repeater remotely close or are they using an IP link. Are they using the same TGids? Where is the information for the new system? I can confirm that TAPD/TAFD are still using the AWIN system as I'm able to actively monitor the AWIN repeater sites.
Since they are using basically the same frequencies, if you still have a Fav list that had it entered, I'd enable it, and set it to ID Search. It's probable that they changed talkgroups if it is indeed linked to GATTRS.I've been using the Uniden BCD436HP. I thought I had continued to hear traffic on the old frequencies (700MHz) but couldn't recall as retail has been picking up for the holidays and haven't really had a chance to monitor (live in SW AR, unable to get a good quality decode on the Texas system).
13E is the System ID used by GATTRS. Motorola's P25 trunking system (Astro 25) solutions are divided into two types. M Core and L Core. The L Core is considered a light or limited core in that it's mainly aimed at small simulcast systems covering a city or maybe a county (such as what most Harris systems are) and is a single zone. M Core has 3 different levels, 1/2/3. The M1 is a single zone, up to 100 sites. M2 is up to 3 zones of 100 sites each. M3 up to 7 zones. Each zone requires it's own core. Zone ID comes across as RFSS OTA.I am new to this Forum. Could you please explain what 13e and Zone 2 are?
Thank you!
Sites are connected directly to the core via IP. In this case it'll be leased circuits and can be T1 or fiber. Motorola typically recommends using two different forms of media (T1/fiber, fiber/microwave, T1/microwave) to complete the OSPF ring. Zone 2 has quite a few sites coming to it in the near future though.It was on the old Bi-State Information TRS. It was then upgraded to use the Bi-State P25 TRS system https://www.radioreference.com/apps/db/?sid=9342 which was removed a few days ago and labeled as deprecated. At the time, TAPD/TAFD would use the AWIN system and TTPD and TTFD would use a "DPS" radio system. Now I'm being told that they're using GATTRS by a Hooks PD officer with no clue about the new system. Question is, how are they using the new system with no repeater remotely close or are they using an IP link. Are they using the same TGids? Where is the information for the new system? I can confirm that TAPD/TAFD are still using the AWIN system as I'm able to actively monitor the AWIN repeater sites.
Bi-State Information is all the same as before, just not P25 Phase II. The frequencies and the talk groups are the same. It is P25 Phase I. I still receive it on my Whistler WS1088 as before. The old Motorola system is pretty much history, with the exception of lifenet (EMS) conventional frequencies. So we have Bi-State Information P25 Phase I For Bowie County and also Awin For Miller and Bowie County P25 Phase I.
According to what’s being reported by the data channel it continues to show as Site 003, same as it did when it was Bi-State P25.
