Hoping someone can help me with this as I've run out of ideas.... First some background. My department uses 2 main channels (VHF) for calls in our municipality, one in the low 150's and the 2nd in the low 170s. Both channels use a PL of 250.3. On both my PD782 and MD782 the first channel works just fine, however on the 2nd channel I only hear dispatch. If any other radio transmits... nothing. I see via the signal strength indicator etc that there is activity on the channel, but no audio comes thru. If I change that channel to CSQ, then it works. I know the PL on that channel is correct as I've confirmed it with my dept assigned portable, not to mention all my other radios work just fine, so it seems to just be a Hytera thing.... All our department gear is Motorola, from older CDM mobiles to XPR7550 portables.
Has anyone else come across something like this? I'm completely baffled at this point as to what could be happening. I was considering maybe some sort of alignment issue with my radio, but the fact that a 2nd Hytera radio does the same thing sort of rules that out. Even more confusing is why dispatch comes thru ok, but nothing else. I've also confirmed with a scanner that when dispatch is transmitting that I'm seeing the same PL (250.3).
Been scratching my head over this one for a while now!
