Jimbo695
Hello, folks. Well, they said that it wouldn't be easy. I have a nice clean Model III Flashport for 900 mHz amateur use. Struggled to download and install the CPS because it only will run on my old Dell Windows XP machine. Obtained a RIB-less cable and also a serial to USB adapter because that old machine only had one serial port that was needed for the monitor. Downloaded and installed two versions of the Prolific drivers (does the installation file location make a difference?). The CPS program sees the com port into which the cable is connected but does not read the radio. Is there some radio setting that must be in place before the program can read it? Should the unit be on or off? Any suggestions please (other than professional programming)?
Thanks !!
Thanks !!
