I’ve had my 436 since last Christmas, best present ever! (Thanks Wendy & Kasey!). I love it. One of the first things I did after getting it was to replace the 2300 mah batteries with 2700’s. Typical use is to charge overnight with batteries in unit and powered off. In the morning I use it on battery power for the 15-20 minute ride to my warehouse. Upon jumping in my work truck, I’ll switch to USB power for anywhere from 8 to 14 hours. Then back to battery power for the ride home. In the evening I’ll listen at home while powered from the wall and connected to my AntennaCraft SC-2 that’s 55’ up on a tower. On weekends while working in the yard or in the garage I’ll run on batteries for 4-6 hours or so.
Here’s the issue. Lately, when I get in the work truck and run it for the day on external power, again, after fully charging internal batteries overnight, by the end of the workday I’ll get the low battery message on the screen. I will unplug the unit and check the on-screen battery level and it will be down to 3.25v. I will clear the warning message and plug it back in and it will continue to run just fine with the exception of throwing the warning on screen off and on repeatedly. I have checked the cable and it is fine. As I understand it, while plugged in, the on board batteries should be off line and the internal clock battery gets charged. By the way, I have not had the clock battery issue. Has anyone else had this issue? What am I missing? Thanks!
