I just purchased my first digital trunking scanner. I have a couple of conventional frequencies that seem to be exaggerating the background noise (static like sound) especially when compared to my BC125AT. The 125 still has its rubber duck antenna while my 996 is connected to a much larger antenna with good coax. I don't see a reason that the 996 is making some of these transmissions completely unreadable when my 125 sitting feet away can receive them perfectly. I expect it from some of the air band stuff but not from these public safety repeaters. I have tried swapping antennas around and moving the scanner away from possible causes of interference. Here is a breakdown of the frequencies for comparison. This is also a replacement...the first one had the same noise issues (also had a non-functional function knob) and the new one hears these the same way. It receives both my local VHF and 800mhz P25 systems perfectly and every other repeater outputs very well. Any thoughts or suggestions?
154.055 - Noisy
154.995 - Noisy
155.430 - Sounds great
154.055 - Noisy
154.995 - Noisy
