Radio Power question
Res21cue
Res21cue
Hi all
Looking to power a Kenwood VHF mobile and a Uniden 996T scanner in a 2016 GMC Sierra. Normally I would just use fuse taps and be away but much to my surprise; the truck has 3 blade fuses which is new to me. Micro3 fuses. I can’t find taps anywhere other than amazon with 3 blades.
There is an accessory blade on the drivers side fuse panel but only 1 but it is beside a 50 relay
My question is....
Can I crimp both positive wires together into 1 female spade connectors and have both units powered from that 1 blade beside a 50 amp relay? See attached pic. Not my pic but same set up except I don’t currently have anything on my blade.
Confirmed this blade is RAP power aswell so it would be perfect if I can run both positives from it.
jackj
NW Ohio
Short answer is Yes. Also a lot of older vehicles have unused fuse slots that have one side populated with a female connection that is connected to either the ignition switch or direct to the battery. You could use a blade type crimp-on to tap un-fused power. Tie-wrap the wire(s) to something to stabilize them.
crazyboy
NJ
You’re planning on powering the two way radio from the fuse panel not the battery?
I'd avoid using fuse taps if you can.
And, as others have said, you don't want to run your Kenwood off a fuse tap for sure.
Ideally you really want the Kenwood connected to the battery. Taping into existing circuits is a common way to get noise into your radio.
As for pulling RAP power to control ignition sense circuits, there's a couple of easy ways to do it…
Check with the GM upfitter guides to see if there is a ignition switched power feed available under the dash. I did an install a while back in a 2017 F350 and Ford installed a connector under the passenger side dash that had a bunch of circuits for various upfitter usage, including a separately fused ignition sense lead. I connected to that and didn't have to tap into existing fuses.
Other option, and I've done this on a few GM's, is to find an unused circuit. The trucks I was installing in didn't have sun roofs, so I was able to find the taped off lead in the A pillar that would have fed the sun roof. I installed a 3 amp fuse in the sun roof slot (rated for 20 amps) and used that.
I'm always a bit leery when I see an install done using fuse taps. While they do work, it only takes a bit of extra work to do a better looking install. Especially if you are going to be doing anything that requires more than a few amps.
sfd119
I'm pretty sure the GMC is similar to the GM Trucks. There's a spot to route a main power wire into the truck without cutting through the firewall or anything.
Power wire: Easy wires through firewall, thought I'd share - 2014 / 2015 / 2016 / 2017 / 2018 Silverado & Sierra Accessories & Modifications - GM-Trucks.com
RAP Power for Ignition Sense: 2014+ R.A.P (Retained Accessory Power) - 2014 / 2015 / 2016 / 2017 / 2018 Silverado & Sierra Accessories & Modifications - GM-Trucks.com
Might be of some use to you.
KK4JUG
GA
MMckenna's right. No fuse tap. That might work for an extra cigarette lighter plug or some fancy inside lighting but the radio:? I wouldn't. The firewall on new vehicles is sometimes lacking for openings. If you're uncomfortable with trying to wire it, go to a professional radio shop and let them do it, including a ground to the frame or something substantial. Just the wiring into the passenger compartment. You can do the rest of it.
And I always label the wire coming off the battery. Repair shops might need to know what that maverick wire is.
N4GIX
Hot Springs, AR
I took my Toyota Camry to an audio installer. I told them to run the wiring from the battery + and frame - that would power a 2,000 watt audio amp. They charged $85 for the job and had it done in less than 20 minutes. :D
N9JIG
Sheriff
Moderator
Far NW Valley
I brought my truck to an upfitter for the antenna and power installation. He installed a relay and high-power line to the rear so I could power my radios with the ignition directly off the battery.
I have not had any vehicular noise issues.
