Monkj2569
I’m very new to scanners, I’m looking at buying a scanner and I’ll I want to listen to is Ramsey co fire dispatch, if I buy a 800 MHz scanner will I be able to listen to this? Thanks in advance
The bc75xlt will not work for the ARMER system. Now if you only want to hear the page go out then it will work on the vhf pager frequency used but you will not hear anything other than the initial dispatch on the Ramsey system. I don’t know what you will find around the $100 price point, new scanners with p25 digital are in the $350 plus range. I have seen them under $150 used occasionally but often times they are still over $200 used. The cheapest way I know of to listen to a P25 system via radio is a $20 RTL SDR dongle plugged into a pc running Unitrunker version 2 beta. I swear by the RTL SDR Systems but you will find as many users who swear at the RTL SDRs as there are users who swear by it.
Woggieee- what towers have you tried RTL with? I run mine full time on 2-001 Hennepin East, 1-009 Minneapolis - both with better results than my 396T, I have had mixed results as of late getting 1-001 Metro Main, 2-002 Hennepin West, and recently I have been getting reception of 2-003 Ramsey which better than I ever recall. I am located North of the Hennepin County Sheriff’s Golden Valley Tower.
Has Ramsey county changed control chan or talkgroups recently. Am hearing dispatch for county fire on VHF analog, but nothing on my digital radio.
Uniden:
296
325p2
396T & XT
436
536
796
996
HP1&2
Whistler
1040
1065
Trx1&2
Realistic
Pro96
Pro106
Pro2096
Pro668
Pro652
Pro197
Pro651
Pro18
The Motorola Mts2000 is an analog only radio.
Yes the Whistler 1040 will work fine . I use on for Ramsey county
Scott
