USA's only Four Meter Amateur Radio beacon
kb4cvn
Silent Key
Nowhere near a paved road, away from the maddening
The USA's only Four Meter Amateur Radio beacon has renewed it FCC Part-5 (Experimental) license for another two years.
Atop Apple Orchard Mountain (Bedford County, VA) in Grid Square FM07fm at a height of 4300 feet.
Callsign: WG2XPN
Frequency: 70.005 MHz CW
ERP 3kW from a Yagi aimed at 60 degrees true north. The trustee of (Brian Justin, WA1ZMS/4) advises that the beacon is operating 24/7. The beacon has been heard via multi-hop E-skip in the UK and other locations in the EU over the past few years. QSL reports are encouraged via the DX cluster or beaconspot.eu.
https://www.eham.net/ehamforum/smf/index.php?topic=113897.0
Original 4M posting when it went on the air. http://www.70mhz.org/index.php?categoryid=1&p2_articleid=365
dlwtrunked
So, just for giggles, I tried out here in California with a discone and an end-fed 70 foot wire. Nothing, not that I really expected anything different.
Easily heard here, as well as his 2m amateur radio beacon-but after all I am in Virginia (Fredericksburg).
spongella
W. NJ
Thanks for the heads up, will see if it can be heard at this QTH.
