SL 7550 (and 7550e) size-equivalent portable capable of analog?
masstech
I've been demo-ing an SL 7550e, property of a radio shop trying to woo me.
I really like this radio! I'm considering getting one for personal use - it'd make a great replacement for my personal 7550 that I only really use for receive and portable operation of the system I manage, along with the most occasional uses of on the various amateur networks and local 70cm repeaters.
Unfortunately... it's MOTOTRBO only. Any recommendations for similarly sized radios that can do both analog and MOTOTRBO, or will I want to also get an SL 3500e to go with the 7550e (at which point, might as well get another 7550e.
Kirk
DB Admin
Hytera PD-362. Not as full featured as the Motorola on DMR, but it does do analog. If the system you manage is trunked, though, you’re out of luck.
K2NEC
If you want a Motorola I would say get the SL3500. It is a nice radio 99 channels and discrete display. I think it will work just fine for your applications.
masstech
Does that mean channel pool+roam systems are out of the question?
I was looking at the SL 3500 as well - it's very nice, although I would appreciate a keypad to support the ability to wrangle contacts and receive messages.
It's really a shame a lower "class" radio can do analog whereas a higher class one can't. Alas...
Kirk
DB Admin
The Hytera PD-362 doesn’t do roaming.
Understood about the SL7550. I’d probably own one if it did analog. I suspect they were worried about heat and battery life, so they omitted it.
N4KVE
PALM BEACH, FLORIDA
Correct. That tiny cell phone battery wouldn't last 10 minutes in analog.
masstech
Actually - the batteries are interoperable. So you can put the larger battery in the SL 7550.
