He's a blasted moron!!!MTS2000des said:This guy is a whacktard.......
So...... How did he become a suspect
I am curious now too how exactly "investigators traced the call back to Beavers..." I'm not a lawyer, nor defending the alleged actions, but how exactly can a case be prosecuted where the defendant was in possession of legal radio equipment and there are no witnesses to the crime?
most likely RDF, but all these Copwatch idiots are always trying to goad officers to do stuff, so i wouldnt put it past him, SMH
Yes, legal radio equipment, however if it's programmed with Part 90 Transmit frequencies the owner is not licensed for, the FCC can bust them under 90.427:
§90.427 Precautions against unauthorized operation.
(b) Except for frequencies used in accordance with §90.417, no person shall program into a transmitter frequencies for which the licensee using the transmitter is not authorized.
Is there any indication the FCC is involved at all yet?
Without doubt 90.427(b) says you cannot program frequencies for which you are not authorized, however has this ever been applied to a private party? Yes, for sure it has been applied to businesses and technicians doing work for hire, but I don't think I have seen a case of a private party facing such a citation unless they had sold the services of programming a radio.
Although on the surface this regulation seems cut and dried, I think possibly the interpretation of it by the FCC is not so clear.
T!
I'm guessing this guy has been on their whacker radar for a while now? When the interfering transmissions began, there was probably a short list of people the Sheriff's department would want to talk to right away - the suspect calls it a "vendetta."
Here's an article with a little bit more info and an interesting quote from the suspects father:
"They may have some audio stating that is Jonathan, but you actually have to prove Jonathan actually mashed that button..."
If this were ongoing and he was on their short list of suspects, all the dispatcher would need to call his cellphone and/or house phone and if it is heard ringing in the background, gotcha!
