INDY72
New year, new thread.
Anyone got anything on Lafayette County? I swear the freqs have changed from what we have in RR as I pick up nothing but the La SO when doing a id search and even that is hit or miss, no real traffic. The freqs are pretty different on digital frequency search.com ( or whatever site searches the fcc database and presents the frequencies.) I’m willing to bet those freqs are the correct ones but I’m not sure how to manually program them in as a proper p25 system in my BCD236HP. The tutorial on the digital freq site doesn’t work for me and finding a straightforward p25 trunking system programming tutorial (phase II although I guess that doesn’t matter,) is eluding my grasp I have both ARC and Sentinal, have all the upgrades (dmr, pro-voice.) any hints, tips, ideas, etc? I’d really hate to have to send this thing off to get programmed, but I’ve had it for about a week and a half and am kind of at a dead end.
Thanks all,
Will
USAF 2002-2007
You mention programming a p25 system but according to the existing info on the D.B. most agencies in Lafayette county are using DMR on VHF conventional frequencies. So what exactly are you trying to listen to? Does your radio have the DMR update?? Have you programmed the VHF frequencies that are in the D.B. into your radio as DMR conventional?? There are a few frequencies that are not in the database that MIGHT be actively in use if you want to check these:
155.49
154.7625
These should be checked to see if they are active or not. They might be analog or digital(DMR...not p25..according to the license).
If you are trying to listen to MSWIN do you know if Lafayette county uses MSWIN??
i know have an 80% belief the 62062 is emepa
