Cdm1250 Tone receiver
FirstDue5
Georgia
Can anyone tell me what model receiver this is that is hooked in with the radio? Been trying to look it up but can’t seem to find anything about it.
Often used for fire stations. A two tone page triggers a relay that turns on station lights. Audio is routed to a PA system throughout the station. The OP could probably explain what they are using it for.
FirstDue5
Georgia
I agree with McKenna, sure looks custom. Can you tell us what it does when there's an alert?
We use DTMF tones to alert our stations, when the proper sequence of tones is dropped, there are alert beeps sent through the station, and then it automatically resets itself.
K2NEC
I think you just answered your question a little bit. When the DTMF sequence goes through the radio picks it up and activates the "box" which probably activates lights, opens doors, etc... As per model it looks like the department made it custom or had someone make it. Maybe to fit their needs more specifically.
mmckenna was correct
Project25_MASTR
Millennial Graying OBT Guy
Texas
The CDM's were a different radio from what is available today. They used simple 12V signalling on the accessory connector. Not too long ago, several station alerting systems my manager had designed which were built with CDM's (essentially a series of relays would be triggered from the output of the radio when a page was received passing audio into a Bogden PA and flipping alert lighting). The department needed to spend some grant money so they upgraded those CDMs to APX1500's. The APX (and XTL) use digital logic for things like channel activity (COR) and don't put out enough current to hold a relay open. Ended up having to re-engineer the alerting system to use a transitor based switch as a buffer to between the APX and 12V relays. Once that was done it worked...but was a pain to do.
