Looking for a little guidance..
I am using an approximately 75 foot run of RG-58 from my rooftop (25-30 foot AGL) base station antenna with a dual band vhf-uhf commercial NMO mount antenna into my home office, to provide signal to my BCT15 Uniden Scanner. I get pretty good reception on low band (45 Mhz), VHF (150 Mhz) from more than 30 miles away, but UHF signals from a mountain top repeater about 10 miles away or less is nearly completely deaf. If I turn my squelch to zero, I can make out some static and intermittent poor quality voice on what should be a very strong signal. The setup is in my home office, but I just don't think my computer is causing the issue. We moved last year from a few blocks over, and I did not have this issue. I have tried several different antenna scenarios on the roof, from a UHF only antenna whip style with 5db gain, to a half wave no ground plane, to a surveillance style antenna but no luck. I have also tried changing the scanner but have the same issue, so I have to assume it is an antenna issue.
Any guidance would be helpful
