hypersight
I'm having a strange problem with my TRX2. Every once in a while when I turn on the unit it will ask me to set the band plan, just like it does when you turn it on for the very first time just after you bought it. After I set the band plan (Canada) it boots up normally, but I lose all my settings such as my custom Welcome Text, Beep volume, blink times, etc etc. However all my objects, systems, and scanlists I previously programmed remain intact.
So I remove the sd card and use the Whistler software to program all my settings and Welcome text again, save it to the card and put it back in my scanner. After doing this, everything is fine for a few days, and then bingo - it happens again!
Anybody have an idea what is causing this?
I have scanned the card for any errors and even reformatted it. I'm using the card that came with the scanner. I've had this scanner for a year now and this just started happening in the last few weeks.
