Maybe try this
https://www.buytwowayradios.com/blo...the_tyt_md-2017_to_store_100000_contacts.aspx
What you need:
*TYT MD-2017 dual band radio
*Firmware V3.33 bin
*V1.17 programming software
*Firmware launcher/installer
*Programming cable
*(Note)*: Microsoft Excel is Currently Required to be Installed on the PC for the Import of Contacts to Work.
*Step 1: Save the correct firmware version to your desktop. In the case of the early release radios, it is V3.33 bin (non GPS)
*Step 2: Double click on the "FirmwareDownloadV3.04_EN.exe" link
*Step 3: Under the "User Program" section, click on "Open file upgrade". This is where you will find the file you saved to your desktop.
*Step 4: Plug the programming cable in to your radio and the USB in to your computer. With the radio powered off, hold down the PTT and orange button and power the radio on. The screen will remain black but the LED light on top will flash red and green. You are now in firmware update mode.
*Step 5: Write the firmware to the radio. To do this, click on the "Download file of upgrade" button. Your radio will now begin to receive the updated firmware. Once the download is complete, power the radio off and unplug the cable from the radio.
*Step 6: Open the V1.17 software and plug the cable back into the radio. If you have a current code plug, the contacts that are in that will remain. This is important for your talkgroups.
*Step 7: Click on the "Program" dropdown and select "Write contacts". A box will open with available buttons "Read, Write, Export, Import, and Cancel".
*Step 8: If you already have a list, you will want to click the "Import" button. After you do this, select the list and import it to the software. The only notification you will get is if it was successful or not. You will not see these in your regular contact list.
*Step 9: Once you get the notification that the import was successful, you will now want to power the radio on and hit the "Write button". The process will now begin. Upload times depend on the number of contacts. With the 64,000+ contacts I uploaded, it took about 5 minutes. Be patient and do not power the radio off!
*Step 10: Once the download is complete, power the radio off and then back on again. Next is the most important step: You will need to go into your menu for the radio, click > utilities > radio settings > ContactsCSV, and turn it on.
Now your radio should be good to go! I think there are a few little things I would like for TYT to fix, but for the most part this is pretty awesome!! I like the display on it. It has the look of a pretty well-known firmware hack from the MD-380 days.
I installed this on my MD-2017 a few weeks ago and have been using it ever since. I also released my csv file containing over 64,000 contacts.
As always, my sales staff and I appreciate each and every one of our customers. We will continue to support you and the products we sell!
73,
Anthony R.
Sales Manager
