G4 Won't Connect to Trunked System
mfn002
Bryan, Texas
I recently acquired a brand-new G4. First of all, here's the system I'm trying to program: Texas Wide Area Radio Network (TxWARN) (P25) Trunking System, Various, Texas - Scanner Frequencies
Anyway, the unit doesn't seem to want to connect to the system, despite the fact that I can receive all of the sites for my county (Brazos) fine on all of my scanners. It keeps flashing "OUT OF RANGE". I've quadruple-checked all of the frequencies, and they are all correct. Am I missing something?
troymail
Silent Key
Did you enter the site ID as HEX or decimal?
Kevin is correct.... make sure the WACN, SysID, RFSS, and Site values are all entered correctly -- or apply wildcard values:
WACN: FFFFF
SysID: FFF
RFSS: FF
Site: FF
If your source of these values is Radio Reference, there is also the possibility that what is listed is incorrect (it has happened to me many times!) and you'll have to use wildcards (or a capable scanner) to determine the true values.
One other (extreme) possibility that probably doesn't affect you - some systems just won't work on a Unication - some of us believe we've gotten that narrowed down to systems that do not send their bandplan/trunking table data in the control channel.
KevinC
Other
Super Moderator
Home
WACN: FFFFF
SysID: FFF
RFSS: FF
Site: FF
If your source of these values is Radio Reference, there is also the possibility that what is listed is incorrect and you'll have to use wildcards (or a capable scanner) to determine the true values.
1A7 info is correct in the RR database.
troymail
Silent Key
If you know you have the correct control channel frequency (i.e. your scanner is receiving it on that frequency) but you're getting out of range, the best thing to do is simply program all 4 of these as wildcards and have the radio tell you the correct values.... and then, if it wasn't your typo, submit the correct values for the next person!
mfn002
Bryan, Texas
What site are you trying to use. I monitor this system daily and I can help you
I’m just interested in the Brazos County sites. As for the system ID stuff, here’s what I put in:
jmontes77029
Baytown, Tx
Use the number in parentheses for the site. You are using the decimal but should be using the hex one. For example the Bryan one should be 15 not 21
mfn002
Bryan, Texas
Looks like you used the decimal values for the SITEs - they need to be hexadecimal.
Bryan is 15 not 21
College Station is 16 not 22
etc.
Thanks. I forgot about that. I finally got it working, but now it's receiving all of the TGs in the system, even ones I have not programmed in. I have each of the channels set to "Trunk TG Monitor". Should this be different?
