In the < $200 range?
Uniden BC125AT for about $100 or for $75 there is the BC75XLT, which is the same as the BC125AT just without alpha tags and pl tones, and a couple other little features. Both are fantastic for air-band use.
First off, if you want the UHF Mil band full coverage, then stay away from the 125AT as it's coverage is clipped from 380 Mhz to the upper edge of the band (399.975). While this section of the band was reallocated to LMR, It's still being used for Military coms... Also, you cannot create custom systems, your stuck with the old school arrangement of "Banks" of frequencies which wastes memory space.
So, moving forward:
BCD 396XT, BCD 325P2 (larger, easier to read display) if you wanna go handheld.
15x, 996XT, 996P2, if you wanna go mobile.
Stay away from Whistler products, as you cannot select custom search step size or mode (very disappointing)
5 cents worth.
Great info, thanks! Being that I have all three, 15X, 996XT, and 996P2, does any one of those excel over the others on the UHF MilAir band?
BC125AT gets my vote as well. It's inexpensive enough for airshow/event listening without the huge worry of loss or damage.
The main aeronautical difference between the BC75XLT & the BC125AT is that the BC75XLT does not include the military air band. That's what made my decision.
All who "really" need full Mil Air coverage above 380 MHz, you can purchase overseas version of BC125AT = Uniden UBC125XLT frequency coverage from 25-88MHz, 108-174MHz, 225-512MHz and 806-960MHz with 5/6.25/8.33/10/12.5KHz frequency steps or Aus /NZ version UBC126XLT with the same coverage.
