As some else said , if your scanner is locked from the hack no. If your on dsp 3.0 or lower then yes. you will have to source the cpu firmware you want, and the correct version of the grefwtool.
If you thinking of sending your scanner in for the legacy upgrade you can send it with whatever firmware is currently on it. If not locked it cost $59.99, if locked it cost $120, if broken it also cost $120
