And drill down to JNCR, select Webster and import selected, nothing is loaded into my Webster channel. I hit scan and the scanner says Nothing to Scan!
Sent from my iPad using Tapatalk
Ah - I finally see what you mean - you appear to be importing the Webster Field
site of JNCR... but you also need some talkgroups in your configuration.
So, what else did you import for JNCR (i.e. which talkgroups?) and into which scanlist did you import them?
There does not appear to be any talkgroups listed that are specific to Webster Field - only PAX.
In addition to the Webster
site, I would import ALL talkgroups and add a wildcard talkgroup. This will result in you hearing any/all talkgroups that become active on the Webster site - listed or not.
Even if you don't want to hear some of those talkgroups, you'll want to go through this step just to ensure you are receiving the site (can see the blinking 'T'). After that, you can lockout any talkgroups that become active but are not of interest.
