DTRS Table Mountain Site Verification Needed
Spitfire8520
I might be completely clueless! =)
Colorado
It turns out that Table Mountain (3-043) is no longer licensed for the database listed primary control channel and is likely using a new one. The old WPOY442 license was modified this past year to remove Table Mountain (and several other locations) from the license entirely and this included 853.075 MHz (primary control channel) and 853.7625 MHz (alternate control channel). The State has the site licensed under WQKM237 and added additional frequencies to that license in 2015, so I am thinking this change happened around then.
It would be nice if someone who happens to be near Granby could catch a log for this site so we can update the database with correct information. :)
The frequencies licensed with WQKM237 are:
  • 851.0500 MHz - In the DB
  • 851.2875 MHz - In the DB
  • 852.0500 MHz - In the DB
  • 852.2625 MHz - New, likely CC
  • 853.6000 MHz - New, likely CC
  • 856.5875 MHz - New
n0nhj
In way too deep...
Lakewood, WA
August logging
Here's my log from August 2017.
Probably 853.600 was the new control, and the 853.075 was read back into the file from previous logs.
Chuck
FileVersion:8
-TowerInfo
#This section is here for information only. With the exception
#of the Call Sign(s), This data is not Read back into the program at all.
System ID : D1C
System Name : Colorado DTRS
WACN : BEE07
Tower Number (Decimal): 3-43
Tower Number (Hex) : T032B
Tower Description : Table Mtn (Grandby)
Control Capabilities : Data,Voice,Registration
Flavor : Phase 1
Call Sign(s) : WPOY442
Timestamp : Thu Aug 24 18:52:13 2017
-Tables
#Format: Table ID,Base Freq,Spacing,Input Offset,Assumed/Confirmed,BandWidth,Slots
00,851.00625,0.00625,-45.00000,"Confirmed",0.01250,1
01,762.00625,0.00625,30.00000,"Confirmed",0.01250,1
-Frequencies
#Format: Channel,Usage,Frequency(/Slot),Input Channel,Input Frequency(/Slot),Input Explicit(1/0),Hit Count
"00-0007","i",851.05000,"00-0007",806.05000,0,3
"00-0045","av",851.28750,"00-0045",806.28750,0,65
"00-0167","av",852.05000,"00-0167",807.05000,0,5
"00-0201","a",852.26250,"00-0201",807.26250,0,0
"00-0331","c",853.07500,"00-0331",808.07500,0,0
"00-0415","c",853.60000,"00-0415",808.60000,0,0
"00-0441","",853.76250,"00-0441",808.76250,0,0
-Neighbors
#Format: TowerID,TowerIDHex,System ID,Channel,Frequency,Tower Name
111,"T010B",d1c,"00-0355",853.22500,"Mines Peak (Berthoud Pass)"
115,"T010F",d1c,"00-0249",852.56250,"Sunspot"
230,"T021E",d1c,"00-0447",853.80000,"Grouse Mountain"
340,"T0328",d1c,"00-0229",852.43750,"Cottonwood"
342,"T032A",d1c,"00-0407",853.55000,"San Toy Mtn"
348,"T0330",d1c,"00-0351",853.20000,"Blue Ridge - Kremling"
352,"T0334",d1c,"00-0261",852.63750,"Prospect Mtn (Estes Park)"
Spitfire8520
Colorado
Thanks for the info Chuck! Looks like enough verification to go ahead and submit the change to the database. It also looks like 853.7625 MHz was read back into the site file since it is no longer licensed, has no hits, and Pro96Com hasn't marked it with any channel usage.
